Transmission Problem
I also have a similar problem but my codes are:
P0748=pressure control solenoid electrical.
P0960=pressure control solenoid A control circuit/open.
P0506= idle control system rmp below expected. Please help and where is the pressure control solenoid A at/located .
David, welcome to the forum!
I've moved this post to a new thread in the Transmission section. You usually don't get a lot of help when you add to an old thread, and 2009 was a long time ago.
It may help if you added more information, such as what year is your truck and exactly what symptoms you have besides the codes you are seeing.
- Jack
- Jack
