Need help asap
I have an 03 f150 with a 5 speed in it. The slave is leaking. While I'm in there I wanna change the bearing, clutch, hydraulics, and slave. Does the clutch need adjusted and if so how does it get done ? All input is welcome. Dad has done them and is gonna help me but he has only worked on the old ones where the clutch had to be adjusted like in 80's Chevys. Thanks for the help !
The clutch is non-adjustable.
Make sure you get the flywheel bench ground and replace the pilot bearing, and it wouldn't hurt to replace the rear main seal. |
Okay thanks. We were planning on adjusting the bearing.
Adjusting the bearing? No bearing in there that's adjustable that I know of.....
Sorry I ment clutch not bearing
The clutch is not adjustable.
Hold on sorry I just retread what I put to you. Let me clear it up. I ment we were just wondering if the clutch needed adjusted. Then if so what to do. But for some reason that got worded wrong and I put bearing sorry glc.
Whether the clutch "needs" adjustment or not, it can't be done.
