Clutch replacement
Old Apr 28, 2013 | 10:40 PM
Spaz88's Avatar
Clutch replacement
I have a 95 F150 5 speed 4wd with a 300 6, my clutch is going out, I was wondering, what is the best clutch i could get for my truck?
Old Apr 28, 2013 | 11:43 PM
OEM. Get a complete kit (disc, pressure plate, slave/release bearing), have the flywheel bench ground or replace it, and replace the pilot bearing.
Old May 1, 2013 | 11:33 AM
grizzstang's Avatar
What glc said. You do not want to cheap out here. I skipped machining the flywheel once because someone told me it was not necessary and my clutch would chatter and grab like crazy as soon as it warmed up. It drove me nuts until I pulled it and had it machined.
Old May 1, 2013 | 12:21 PM
Also - would be a good idea to replace the rear main seal as long as you are into it that far - as long as it's replaceable without dropping the oil pan. The one in my 4.2 V-6 is.
