Gears
Gears
If I put a 3 inch body lift on my 2003 Ford f-150 and I add like 28 inch tires should I worry about the gears or anything ? The tires will actually probably be smaller then that I'm wanting more like 20 inch tires, but somewhere in that range.
^This. If you are going with a lift, you want to go bigger tire, not smaller. 33's at a minimum.
Are you talking rim dia or tire height??
28" tall tires are CAR tires..
20" rims are different all together..
I've got 32" tall tires on a 16" rim (LT265/75/16)
3" body lift, you'd want 33" tires at the minimum.. My 32" look fine on a NON LIFTED rig..
Until you get over 33" tall tires, you don't have to worry too much about 'gears'..
Mitch
Mitch
