Heat Problems?
Old Feb 11, 2012 | 09:13 PM
What brand of plugs and cops did you use?
Old Feb 11, 2012 | 09:19 PM
GatorBoi's Avatar
motorcraft plugs and the cops i have no idea
Old Feb 12, 2012 | 10:24 AM
GatorBoi's Avatar
Could this be the transmission? I read about the Torque Converter going bad or the tranny getting flushed and fixing it. Hope its the cheaper of the two!
Old Feb 12, 2012 | 11:03 AM
EsJayEs's Avatar
No. The problem you're describing sounds like a misfire. Since replacing the plugs (which I assumed you gapped correctly), have you had the computer scanned? Codes would be helpful.
Old Feb 12, 2012 | 12:15 PM
Where did you buy the cops?
Old Feb 12, 2012 | 08:02 PM
GatorBoi's Avatar
I havn't scanned because I never got a CEL again. Makes since it could be a low level misfire and the light isn't comming on. I made sure all the plugs where gapped correctly but the CoPs on the other hand where relativly cheap. Maybe 100$ for all 8. That could be where my problem is comming from, cheap cops.
Old Feb 12, 2012 | 08:54 PM
The cheap Ebay cops are generally okay, but frequently will have one or two bad out of the box. That's why we recommend the 10 pack so you have a couple of spares.
Old Feb 12, 2012 | 08:57 PM
GatorBoi's Avatar
well I kept the old ones but i'm not sure which one was the bad one/ones. I also have 1 brand new one. Guess I should see if there are any codes stored then go from there.
