Servo trouble
Old May 16, 2011 | 05:41 PM
mattbailey69's Avatar
Servo trouble
i need help. my transmission worked fine until i towed it behind y truck. i talked to a guy and he told me it might just be my servo out. i can't find any information about it online. can anyone help me? its a 98 expedition 4x4 with a 4.6l
Old May 16, 2011 | 06:36 PM
piston91's Avatar
You mean you got your truck towed while the wheels where on the ground? If so and your engine was not running you more the likely smoked the tranny. Because the oil pump is turned by the crankshaft and not by the output shaft fluid was not moving in the trans while it was being towed.
Old May 16, 2011 | 08:02 PM
Mark Kovalsky's Avatar
What isn't working right?
Old May 17, 2011 | 07:09 PM
it won't go in reverse after it warms up, it only has 1st and 2nd and it slips at 3 grand. yes i towed it with the wheels on the ground, in 2 wheel drive with the transmission in neutral. i figure if i blew a band then it wouldn't go in reverse period. but it will when i first start it up and yes the engine was off
Old May 18, 2011 | 01:30 PM
You toasted it - you can't flat tow it without removing the driveshafts. I'm assuming you didn't read the owner's manual. The only exception is 2wd vehicles, they may be flat towed without removing the driveshaft for up to 50 miles and you cannot exceed 35 mph.
Old May 18, 2011 | 07:57 PM
i've towed 2 wheel drives at 75 mph for 30 miles alot. when i lived in the country that was the nearest shop. and what do you mean toasted? bands? servos? stripped gears?
Old May 18, 2011 | 10:06 PM
A lot of parts were probably toasted. When you tow it about half of the trans is rotating, but the pump is not. That means half of the trans is running, but no fluid is being pumped for lube. It needs to come out and be torn down to find out what happened.
Old May 25, 2011 | 05:40 AM
Robinwood's Avatar
Once i too got the same problem but thank god one my friend who is a master in this field had set it into the right position !...
