transmisson problem
before i toolk my truck to a autoshop i wanted to ask if anybody knew anything about this before i went and spent all the money a shop costs
my truck has been jumping out of gear recently heres the info on the truck please leave thought on what it may be it will really help me out alot World Manufacturer Identifier - 1st, 2nd, 3rd Positions: Manufacturer: Ford Motor Company, USA Make: Ford Vehicle Type: Truck (Completed Vehicle) Brake Type and GVWR Class - 4th Position: Brake System: • Hydraulic brake system, Class E, GVWR 6,001-7,000 pounds, None Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions: Line Series: F-Series - F150 Chassis Type: 4x4 Body Type: Regular Cab Styleside Engine Type - 8th Position: Engine: 5.8(351cid) Cylinders: V-8 Fuel Type: Gasoline Horse Power: TBD Model Year - 10th Position: Model Year: 1994 Assembly Plant - 11th Position: Assembly Plant: Norfolk: Norfolk, Virginia Production Sequence Number - 12th - 17th: Sequence Number: B12297 |
Most likely your Manual Lever Position Sensor (MLPS) is failing.
thank you any price range on that??
Depends on the transmission - assuming an E4OD an aftermarket sensor is about 50 bucks.
i took it to the shop today and they took a look at it and i mentioned that might be the problem and they told me thats not the problem cuase its not showing up on the tests
It usually won't show up in tests. If you use a scan tool to monitor PRNDL sometimes you can see it jump from D to N. Usually I just change the sensor because the fault happens so fast it is hard to detect. It NEVER will set a code.
i mean like when u accelerate the truck will jump out of gear as in like gear 1-5 not from drive to neutral
