Installed Shift Kit Now Truck Won't Move?
I just finished installing the Factory Tech shift kit and when I put it in gear the truck won't go anywhere. I installed everything according to the instructions and plugged the sensors back in etc but when I try it in any gear the truck just revs and won't go anywhere...any idea what could be the problem??
I take that back it only moves when I put it in "1"
Also per the instructions I took the spring out of 2-3 piston and on the 1-2 piston I used the factory tech spring up top and one of the original springs on the bottom...
Might want to try the Trans forum on this site. I would. :thumbsup:
BTW- Have you re-booted ? That would be the first thing I would try. This not only clears the KAM's AF's, but it clears Trans tables. Not sure that will help, but it's worth a shot. I tuned my trans as well, thru hardware, - about 3 years ago. Reason: I wouldn't move as well, just slip. Hows Reverse ? BTW- Post your trans model, you have NO info top right corner, - not even a signature. So, if you want help, post engine, trans, tow package every post until you get your info filled in correctly. |
My bad I'll get that updated it's a 98 F150 4x4 with the 4R70W transmission
I just finished installing the Factory Tech shift kit and when I put it in gear the truck won't go anywhere. It does move a little when I put it in "1". I installed everything according to the instructions and plugged the sensors back in etc but when I try it in any gear the truck just revs and won't go anywhere...any idea what could be the problem??
Also per the instructions I took the spring out of 2-3 piston and on the 1-2 piston I used the factory tech spring up top and one of the original springs on the bottom... BTW This is a 1998 F-150 4x4 with the 4R70W transmission |
Yea, get a thread goin in the tranny forum. Like -
Factory tech VB install/ Truck won't move??? Then Engine , trans 4r70w 4x4. Also, search this ~Factory tech VB install~ in the trans forum only. You can do this from a drop down menus @ the right, by forum tools. - Once your in that forum. |
You have a thread goin already, great! In the mean time, try search over their. - Here's one I looked up real quick. There's allot of them, this was at the top -
https://www.f150online.com/forums/tr...tor-plate.html |
Is it possibly just a bad valve plate? I took it back apart and everything else looks fine....wtf
I got it fixed I didn't have that manual valve lever or whatever lined up right lol
Thanks I been lookin at that one too. Good news!
I got it fixed. It was that manual valve lever or whatever I didn't have it lined up correctly so it didn't have nothin to grab on when I put it in gear. |
Originally Posted by cullenpowell
(Post 4230143)
http://www.crownvic.net/bok/ODservo/8.jpg |
Good to see ya got it figured out, I did that too on my truck the first shot. I was so bummed thought I messed up really bad.
Originally Posted by Klitch
(Post 4230250)
:lol: time flies.
Yeah I had just ran my whole right arm through the press, crushed my hand and forearm all the way up to my elbow, I never knew my arm would fit through a 3/16"-1/2" tall gap |
