Drain plug kits?
Old Mar 14, 2010 | 10:09 PM
ehlersad's Avatar
Drain plug kits?
Has anyone installed one of those drain plug kits in your stock pan? I need to service my transmission and was thinking about installing one or those drain plug kits from Troyer or B&M. Any leaks with these?
http://www.troyerperformance.com/cgi...logno=PPI-TPDP
Old Mar 15, 2010 | 12:27 PM
38Chevy454's Avatar
I just drilled a 1/2 inch hole then welded a 1/2 fine thread nut to the outside of the pan on the side. Short 1/2 fine bolt and nylon washer seals it up great. Much easier to change trans fluid now.
That Troyer fitting you showed should work fine as a non-welded solution.
Old Mar 15, 2010 | 06:14 PM
Dennis Nicholls's Avatar
Lightbulb
There's even a Ford OEM pan with a drain plug in it, sold to places like U-Haul.
https://www.f150online.com/forums/tr...-question.html
If our "image server" ever stops being "busy" that thread has links to pictures of said pan. It might be a good idea to put your aftermarket plug in the same place the factory did.
Old Mar 15, 2010 | 08:32 PM
Roadie's Avatar
If you do install one, make sure you get a rubber o-ring to seal it. Those hard plastic rings that come with the kit WILL leak. Ask me how I know! I have used washers with rubber inner rings that were made to use with engine oil pan drain plugs to seal them also.
Old Mar 16, 2010 | 06:15 PM
BlueOvalFitter's Avatar
Thumbs up
I welded a 1/4" thread-o-let onto my pan.
http://i206.photobucket.com/albums/b...r/PICT0081.jpg
http://i206.photobucket.com/albums/b...r/PICT0080.jpg
Old Mar 16, 2010 | 07:35 PM
deerhunter7979's Avatar
Be sure to follow the advice given and WELD the drain in. I used the white plastic washer also and I am paying for it with a drip. Not much, but enough to be a PITA. Uses 1/2 cup fluid each 3-4 months. Not enough to worry bout yet.
Old Mar 16, 2010 | 10:00 PM
ehlersad's Avatar
I think I am just going to skip it this time. I will buy a new aluminum pan when the time comes to do the service again. Thanks for all your replies!
