will a f250 4r100 fit a lightning?
will any 4r100 rwd tranny fit on a lightning. Will it work with everything the computer and the wire harness as well.
Originally Posted by fritz4077
(Post 4110920)
Darrin |
Modular bellhousing pattern is what - 4.6, 5.4, 6.8, but not a diesel?
it should work, and can be converted to 2WD from a 4WD given the tailshaft bolt pattern is the same. Essentially the 4R100 in the gas jobs is the same from series to series. As for the electrical I am almost 90% sure it will work, I wish I was at my shop right now I could say yes or no lol
so will it work with the lightning ecm too or what
yes it should be direct, if not the 2 things you need to llok at is the 2 speed sensors on the side of the transmission, and the electrical on the Valve body, if they are the same it "should" work no issue....
