transmission shutter
when im driving and it changes into the overdrive gear it will shutter and
gitter, sometimes bad sometimes almost no at all. its a 5.4 auto 4x4 and i cant figure it out.
thanks
thanks
its a 2000 with 79k and its also the 7700 series. i bought it recently so the dealership changed all the fluids in the truck and im not sure about the spark plugs. o and by the way what are the coils you mentioned?
thanks
thanks
The ignition coils that are on top of each spark plug, you don't have a distributor or coil packs or spark plug wires. At 79k, if the spark plugs have never been changed, it's about time to do it. Did the truck come with any kind of warranty?
well if anyone still cares i took my truck to a transmission place and they said that it is a low grade misfire. then they said i need to change the spark plugs and boots. does this sound right?
thanks for the replies
Pack a lunch. Make that 100 mile drive and take advantage of your warranty.
Yes it does.
