Question on tc or u joint
Old Oct 27, 2008 | 07:56 PM
toolman01's Avatar
When i accellerate up to 70mph on the express way it seems like i get more and more of a humming/ vibrating noise. and it seemes that the torque convert is sticking alittle, when i let off you can feel the trans drag me down some. When i put it in neutral it all goes away. Can some one please help me out here?
I have a 2001 supercab xlt with the 5.4l and 4x4 if this helps.
I have a edge programmer but it does this with it installed and uninstalled.
Please give me a idea where to start.
Old Oct 28, 2008 | 09:56 PM
toolman01's Avatar
anyone?
Old Oct 28, 2008 | 10:13 PM
toolman01's Avatar
anybody?
Old Oct 28, 2008 | 10:34 PM
chiefFX4's Avatar
what do you have the edge at? when i was playing with my edge to get it where i wanted i know it would drag when i took my foot off the gas.
if i remember correctly it was changing the shift speed that seemed to effect it the most.
..edit..
sometimes it takes a little bit for the new parameters to adjust to your driving so switching from the edge to stock and back without giving it some drive time could cause this.
wreedKR's Avatar
sounds like your tc or tranny is starting to have issues.
Old Oct 29, 2008 | 09:55 PM
toolman01's Avatar
I know i have a issue but ware to start, do i just take it in or try and figur it out my self?
Keep te help coming guys.
Old Oct 29, 2008 | 10:39 PM
I would start with a trans flush, when was the last time you did one (mileage?)
Old Oct 29, 2008 | 11:24 PM
toolman01's Avatar
80,000 ish and i now have 118,000
Old Oct 29, 2008 | 11:27 PM
toolman01's Avatar
I search the web here and just to help, the trans has never shuddered or hummed before.
Feels like i have a engine brake, when i let off it stas in gear and drags me down some.
Old Oct 29, 2008 | 11:30 PM
you could also try unplugging the battery overnight and connecting it back up to reset the computer.
40k isnt too unreasonable to do another flush. Have you ever changed the filter?
Old Oct 29, 2008 | 11:49 PM
toolman01's Avatar
no i have not, and funny u metioned battery because i have had some stupid corrosin issues on the terminals. I replaced the negative then the posative the next week. Maybe it all starts from that.
Old Nov 4, 2008 | 08:27 PM
toolman01's Avatar
I checked my trans fluid and it was low so i filled it up ad still does it, But i was wrong before, when i put it in to nuetral it stll makes the same noise. any ideas,U joints or still in trans.
Old Nov 6, 2008 | 09:28 PM
toolman01's Avatar
It turned out being my hub bearing on the driver side.
Its all better now.
Thanks for the help and info folks.
