e40d and fluid???
Old Jan 29, 2008 | 04:55 PM
johnnyf150's Avatar
e40d and fluid???
Is it ok to use Mobil ATF GM Dexron-111/ Ford Mercon Multipurpose Automatic tras Fluid In my E40D trans??
Thanks john
Old Jan 29, 2008 | 07:59 PM
Mark Kovalsky's Avatar
Yes, that's fine.
Old Jan 29, 2008 | 09:12 PM
chapdog's Avatar
Thanks john
yes as long as its dexronIII/Mercon.newer trucks take something different Mercon V
Old Jan 30, 2008 | 05:48 AM
johnnyf150's Avatar
Yes its a 1992. Thank you
Old Jan 30, 2008 | 05:49 AM
johnnyf150's Avatar
Originally Posted by Mark Kovalsky
Yes, that's fine.
Thank you Mark
Does anybody know how many Quarts with filter??My bood does not show it
Old Jan 30, 2008 | 05:50 AM
johnnyf150's Avatar
If you both where to get trans fluid for my trans,What fluid whould you get??? I have a case of The multipurpose thats why i asked.
Old Jan 30, 2008 | 07:46 AM
If you are going to drain the pan and the torque converter you need around 18 quarts.
You might also want to read this article. It's another way to change the fluid, and is VERY effective at getting out even more than draining the pan and torque converter.
http://www.ford-trucks.com/article/i...nsmission.html
Old Jan 30, 2008 | 07:53 AM
johnnyf150's Avatar
Thanks again Mark
Old Jan 30, 2008 | 10:56 AM
44dwarf's Avatar
92 should have MERCON V in it.
My 87 f250 does as does my 96 f150
Old Jan 30, 2008 | 11:29 AM
johnnyf150's Avatar
The haynes book says,C4,C6,AOD 81 0n use,Mercon(ford Part #Xt-2-QDX Or DDX)??????????
Old Jan 30, 2008 | 01:40 PM
E4ODs ALWAYS required MERCON fluid. They were not changed to MERCON V in '92 like the AOD, AODE, and 4R70W when it came out in '93.
Having said that, Ford has discontinued MERCON fluid. You'll still find it for a while. Ford changed MERCON V so that it is now backwards compatible with all applications that used to use MERCON.
So the real answer is yes, MERCON is fine for the E4OD, but now MERCON V is the recommended fluid.
Old Jan 30, 2008 | 02:47 PM
johnnyf150's Avatar
And here i thought chevy can get complicated at times I have had the oil for about 5 years in the shed. I dont mind buying different if it will be better. I hear i have a very good trany if i change the Fluid and filter reguarly.
So what would you get and put in the tranny. MERCON V ?
Thanks Bud
Old Jan 30, 2008 | 03:30 PM
To answer your question, I have a 4R100, which is basically an updated E4OD. I need to change the trans fluid soon, and I have some older MERCON fluid. That's what's going into it. If I still own it when it needs the next change I won't have any MERCON left, so then I'll use MERCON V.
Old Jan 30, 2008 | 03:47 PM
johnnyf150's Avatar
Someone got into my case(12 quarts) and theres only 8. Can this fluid be Mixed??
John
Old Jan 30, 2008 | 04:06 PM
THAT is not recommended - you should not mix Mercon and Mercon V. You are going to need more than 12 quarts for a complete drain anyway.
