big leak!!
big leak!!
I have a big leak coming from that little plastic insert on the bottom of the fly wheel. i have the 4r70w and at first i thought it was the seals. i changed all the main seals and gaskets and it does not stop leaking. Its leaking from that plastic insert and the leak gets worst when i accelerate. Like i said i have changed all the gaskets and seals but still cant find the problem. Is there something im missing? If i put it on drive it engages with no problem but the leak is non stop. Thanks
I don't know much about transmissions. But you may first want to identify the liquid that is leaking I assume out of the trans/bell housing inspection plug. Engine oil can leak through the plug from a rear main seal leak. Coolant can leak there also from a freeze plug and of course transmission oil either from a trans seal or the Torque converter. What kind of liquid is it?
Was it the engine main seals you replaced or the trans ? If it was the trans you could have a scored converter hub not sealing right in the front pump seal and or it has damaged the new one you just put in. If you take the trans out have the front pump hub bushing checked also.
Originally Posted by catch
i have the same problem, and its definitely coolant.. what can i do ?
-Craig
