auto to stick
Old Oct 9, 2007 | 07:43 PM
XLT250LD's Avatar
Question auto to stick
I have a 99 f250 LD and I hate the sloppy shifts when I tow and was thinking of swapping it out for a stick. Would it be worth it or should I get a programmer to firm up the shifts? What would you guys recomend?
Old Oct 10, 2007 | 03:14 AM
Which auto do you have? (If you don't know, look at the code on the door jamb sticker and look it up in the sticky thread at the top of this forum)
Old Oct 10, 2007 | 07:17 PM
Veteran: Army
if you have a 4r70
look at a factory tech valve body and C-plate or just the C-plate at a minimum
it really helps
Old Oct 11, 2007 | 02:37 PM
XLT250LD's Avatar
as far as i know it has an e4od that has already been rebuilt at 56k and since than i put about 30k on the tranny
Old Oct 11, 2007 | 03:55 PM
If it's a 99 I doubt it's a E4OD, it's more likely a 4R100, door code E? They are pretty much the same tranny but there may be differences in service parts and mod parts.
Old Oct 12, 2007 | 11:57 AM
adrianspeeder's Avatar
It's a 4R100. Twin brother from a different mother to the E4OD.
Anyway, If'n you'd like a stick, you'd have to find one that came behind a 4.6L (light duty M5OD-R2), or a Superdutys five or six speed with a 5.4L or 6.8L and maybe a 6.0L. Not sure on the heavy duty ZF trannys fitting under the cab of your truck. The computer will throw a CE light for not having a tranny hooked to it, but won't effect engine operation.
Anything can be done obviously, but is the time worth it to you?
Adrianspeeder
Old Oct 12, 2007 | 12:29 PM
I wouldn't put a Mazda box in a 5.4 in a 3/4 ton truck.
