F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Transmissions (https://www.f150online.com/forums/transmissions-25/)
-   -   What's that plate for? (https://www.f150online.com/forums/transmissions/295031-whats-plate.html)
Austin83 Jul 27, 2007 10:34 PM
03 F150 Supercrew FX4....I found a missing bolt on a plate that bolts on right in front of the torque converter inspection hole. The plate has no gasket, seems a bit flimsy, and only has two threaded bolts holding it on to the housing. I threw a ziptie on for a quick fix. What exactly is the purpous of the plate, and does it require an immediate new bolt? Thanks in advance.
Austin
torkum Jul 28, 2007 07:05 AM
Its a inspection plate and a rock shield. Also when removing a engine the shield is taken off to access the torque converter bolts. The zip will do for now.
