How to re-fille front axle housing with fluid.
Guys I have a 2001 f-150 5.4L 4x4. I had to replace the front axle housing tube and lost some fluid. I need to re-file the front axle housing but I'm not sure how or how much or what type of fluid to use. Can anyone make any suggestion on how to do this? I thought I was a pain to replace the front axle housing tube, but I have no clue how to get the fluid back into the axle front housing. Thanks
MP
MP
On mine (99 w/ the 5.4 also.) the front axle is an 8.8, and has two plugs clearly labeled "Fill" and "Drain"
Park the vehicle on level ground, and stick a 3/8" ratchet in the "Fill" plug, and unscrew it. Fill with fluid until it starts coming out, then replace the plug.
Should be good to go with that.
Again thats assuming you have the same front end, but Im pretty sure it would have a fill plug anyway.
Originally Posted by mig25
Good rule of thumb. Always remove the Filler Plug first. Not the drain.
I case you can not remove the filler plug you will not be stuck with a dry differential.
Cheers !
Cheers !
I use either Royal Purple or Amsoil gear lubes in the respective weights. They are both cheaper than the MC brand and both are still synthetic.
