Modulator help
I have a 97 F250 with a 5.4. Where is the transmission modulator valve, and how do I know if it's working for sure?
What seems to be the problem?
On the modulator, there is none. This is an electric controlled transmission and not vacuum controlled like the old transmissions types.
If the noise changes like you hear , there very likely is a vacuum leak/bad hose. |
Could be your strater hanging up. Does it happen every time you start it?
