1994 F150 w/ 5.0 aod ECU/TCM Question
Sorry for first post this is my dads truck and I'm trying to help him out a little bit. I need to know if the 94 5.0 F150 w/ aod has a tcm or if the transmission controls are in the ECU?
I know the 94 Explorer it was built into the ECU and just want to make sure I believe the tcm/ecu is going out and just needed some quick tips. What the truck is doing is, Anywhere from 20-80mph it "feels" like it slips out of gear and revs up then as quickly as it happened you hear what sounds like the drivetrain slam against the rear differential. Apparently this has been going on a long time because I was just informed that they had the transmission rebuilt 2 years ago and they had it checked by a different transmission place 6months after. No one has determined the problem, I just found out about it so I haven't really been able to determine anything else. Any help would be appreciated and I'll try to post back to update if I find anything else out. |
Howdy, just like your exploder the main computer controls the tranny. Also not an AOD, check the trans code on the door jam and U is the 4R70w and E is the E4OD.
Adrianspeeder |
thank you kindly good sir
Now gotta go grab an ECU to slap in there, thanks again! |
Very important to get the exact computer. '94 had a lot of choices with three tranny choices and the 5.0 could be speed density or mass air flow. Might wanna do some reading at www.fordfuelinjection.com
Adrianspeeder |
After you spend a few hundred $$$ on a new PCM you'll find it made no difference.
Next, change the TRS. That's the Transmission Range Sensor, also called the Manual Lever Position Sensor, and also called the nuetral safety switch. That's the real problem here. |
Next, change the TRS. That's the Transmission Range Sensor, also called the Manual Lever Position Sensor, and also called the nuetral safety switch. That's the real problem here. Adrianspeeder |
A big problem with the TRS is that it won't set any codes until it completely fails. It can cause these symptoms for a couple YEARS before the sensor gets bad enough to set a code.
thank you thank you thank you
Can't say it enough, BIG help. I'll do some of the test from that link and probally go ahead and change the ECU and TRS out. I think I can get the TRS for free and the ECU I have someone telling me 50 bucks or so, so I'll probally do both at the same time just because I rarely have time to make it over to my parents. Thank you guys so much |
