Aye ! she's sprung a transfer case leak...
went down below to install a different vss gear and I found this:
damn ! u-joints and seals ? http://www.wannatonka.com/images/f150/1.jpg http://www.wannatonka.com/images/f150/2.jpg http://www.wannatonka.com/images/f150/3.jpg |
How much play in the output shaft? Is the bushing bad? Maybe a bad or out of balance drive shaft. The seal went bad for a reason.
there's a little play in there, should there be none at all or is some acceptable ?
basically, i'd just like a "heads up" from you pros b4 i take it in. |
Pull the slip yoke off and examine it for any signs od wear.
My seal leaks and the bushing is shot. I have grooves cut into the slip yoke. Not a high priority as the damage is already done. When I get around to it I will replace the bushing, seal and U joints. I do not recommed that you wait. Check it and fix it asap. You may save the slip yoke if you get to it now. I was too late. Regards Jean Marc Chartier |
leak
Why is the leak going forward on the trans? It should be a little drier before the seal. I would wash down trans and verify the leak first:D
Re: leak
Originally posted by Boatboy1996 Why is the leak going forward on the trans? It should be a little drier before the seal. I would wash down trans and verify the leak first:D |
Looks like the rear seal leaking to me. Every ford I have had eventually did it. I weeps from the seal and runs down the housing. Thats why it looks the way it does.
