What is this?
Old Jan 2, 2005 | 08:58 PM
crain's Avatar
Question What is this?
What are the symptoms of the transmission slipping? What do guys mean when they say their transmission is slipping? What does it feel like? I have no problem with my transmission engaging or changing gears, but sometimes my rear wheels feel as if they are, ever so slightly, spinning when I start but I know they are not. I suppose I could also discribe this as a slight grinding sound from the rear end. This does not happen everything I start from stop but enough to cause me to ask what's going on? Could this have something to do with my rear end gear change from stock to 4:10. It was completed about 8 months ago?
Thanks in advance for your replies.
Old Jan 3, 2005 | 06:51 AM
crain's Avatar
still...
Old Jan 3, 2005 | 08:13 AM
RockyJSquirrel's Avatar
If your transmission is slipping, you will know it. The symptoms are..... well, your transmission is slipping (as in disengaged).
Old Jan 3, 2005 | 09:17 AM
mcovert's Avatar
you'll notice it mostly when starting out on a hill. releasing the clutch and the vehicle just creeps forward, or goes backwards.
Old Jan 3, 2005 | 10:09 AM
crain's Avatar
Guys, thanks for your relies. Based on what you have provided, it is not my transmission...thank God. I was looking at the rear differential this morning and noticed that it looks dark and moist as if I am losing rear diff. oil. I have not notice a pool of oil under my truck, but could my problem come from a lost of rear diff. oil? The pan looks 100 years old and beat up. Would you recommend me getting a new rear differential pan, gasket seal, and adding lubricant as needed?
