4 wheel drive problem
My F-150 has the 4 wheel drive shift on the floor, it's not a dial switch. When I shift into 4 high.. the 4 high doesn't always engage. 4 low also has some problems engaging. when I do work it around some and get it into 4 high or low.. it doesn't always want to disengage. The truck has 90,000 on it. last year when I bought the truck with 80,000 the shifting worked fine... although pretty tight on the shifting. It has an automatic transmission. What can I look for. Is there linkage somewhere that might be working kind of rough.. or changing the transmission fluid... not sure where to start.
thanks shannon |
Lube the linkage with motor oil. Try shifting in and out a few dozen times to work the oil into the linkage. If that doesn't work check the oil level in the T-case. it shouild be at the edge of the fill hole.
Regards Jean Marc Chartier |
thanks for the help.. that did the trick.
thanks again for your time Shannon |
