Fluid Problems!!!!!!!!!!Help
Old Feb 12, 2004 | 05:03 PM
BigWambles's Avatar
hey guys i have a 95 f150 with a 5 speed trans in it!!!!!! I have been driving one now for about 3 months and am not the best at it.................i can drive around town all day fine but i think i ride the clutch a little more than i should. The little thing that holds the brake fluid for the clutch i have to fill up like every week, some mornings i have to or it wont go into gear!!!!!! What is the problem u guys think its cause i ride the clutch a little too much which uses up the fluid or something may be mechanically wrong with it!!!!!!! Please give me your opinion i know i may ride the clutch a little too much but dam every week having to fill that thing up!!!!!!! Thx guys!!!!!
Old Feb 12, 2004 | 06:37 PM
01screw's Avatar
Riding the clutch will wear out the bearing and disc but has nothing to do with fluid loss. You have a bad leak somewhere in the clutch system - master or slave cyl, lines and hose etc.
Old Feb 13, 2004 | 02:25 PM
Lago_F150's Avatar
I agree with 01screw. Normal wear and tear will deplete the fluid over time. If you are losing that much fluid that quickly you have a serious leak somewhere. With it losing that much fluid that quick you should be albe to easily find the leak.
