Performance Torque Converter ?
Old Mar 18, 2003 | 08:16 AM
evo's Avatar
evo
Question Performance Torque Converter ?
I need some input on which performance torque converter to buy( which stall speed). I cruised the internet and saw a big differance in prices. Any help would be appreciated.
Old Mar 18, 2003 | 07:25 PM
Neal's Avatar
Cool
HI!... I'm running a 2400 stall converter in my BUILT 4R70-W. I had mine built custom for me by a buddy that owns a tranny shop. I got mine for $900.00(CAN) and installed it myself. It's worth twice that. I highly recommend one. Just don't go over 2400rpm because you have a 5.4 like me and it makes it's max tq at 2300 rpm. If you go too high of a stall, you will be wasting that low end tq.
Old Mar 18, 2003 | 09:25 PM
evo's Avatar
evo
Thumbs up
Thanks Neal, Do you know where I can get a high flow fuel rail for the 5.4? I'm thinking about getting rid of my FMU putting larger injectors and higher flow fuel pump.
Old Mar 18, 2003 | 10:25 PM
Neal's Avatar
Cool
HI!... Well the LIGHTNING is running the same size fuel rails as you and making more power than both of us too. I think it is same to say that you don't need to upgrade to bigger fuel rails yet. I'm running 24LB injectors and am still N/A. I see you are SC'ed. You might want to switch to 42LB LIGHTNING injectors, 90mm "L" maf and a WALBRO in tank fuel pump. Don't foget to get your chip re-yuned for those mods. Your times are not bad for a SC'ed truck but they could be a lot better. Have you had a dyno tune done yet? I'm running the 1/4 faster than you and I'm still N/A. Just curious.
Old Mar 19, 2003 | 07:51 AM
evo's Avatar
evo
Hi Neal, Thanks for the reply. I checked out your pictures...cool. We actually have a shop in town with a dyno $180 for the full Monte. Do you think I should wait until I do the mods or get a baseline and see where I'm at now? With those changes I should be able to can KB's boost a pump. Should I go 3.73's or 4.10's?
Old Mar 19, 2003 | 04:43 PM
Neal's Avatar
Cool
HI!... If I were you I would go get a dyno run or two done now. This way you can see if your A/F ratio's are way lean or rich. Lean is very bad espiecally in a SC'ed application. It's probably going totake you a while to save the funds needed to buy all that stuff I mentioned above. So at least this way you can drive around with a safe tune until you get the other parts. If you need a SUPERCHIP reprogramed or any of those parts above I mentioned at a good price. Give MIKE TROYER a call at PERFORMANCE PRODUCTS. 1 (540) 862-9515. He's known as the SUPERCHIPS DISTRIBUTOR here on the site. He spends most of his time in the COMPUTER CHIPS section. I get ALL my parts and chip tuning from him. Tell him I sent you his way. He'll treat you right.
