F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Transmissions (https://www.f150online.com/forums/transmissions-25/)
-   -   Can't fix it?! (https://www.f150online.com/forums/transmissions/100402-cant-fix.html)
FordMX Dec 19, 2002 09:28 AM
Can't fix it?!
Hey all,
I just got back from the speedometer place to have a new speedo gear installed. When I came back to pick up the truck, the guy said they don't make a gear small enough to fix my speedo. :mad: I don't have anything radical done to my truck, it's a 1998 with 4.56 gears and 33" tires...this doesn't seem right to me. I can't remember exactly what size I would need but I think it was 20 or 21 tooth, which he said they don't make. I originally had 3.55 gears and stock tires before the changes. Can anyone shed some light on this for me? I know there are people with MUCH bigger tires and gears than me, so I would figure a gear would be available??? :help:
Thanks,
Chris
WLF Dec 19, 2002 09:45 AM
The largest gear from Ford is a 20 tooth gear and I think you will need taller then that. You can get a 23 tooth gear from Mustangs Unlimited here http://www.mustang-unl.com/ .
I have the 23 tooth with 430gears and 30.5 inch tires and it is still running the speedomete about 3-4% too fast. You may need to go with one of the electronic correction devices.
Read this post to see how LE PEW corrected his
http://198.65.157.241/forums/showthr...hreadid=100164 I may end up going for one of these myself.
Good luck, hope it works out for you...:rocker:
LE PEW Dec 20, 2002 08:53 AM
Speedo correction
FordMX, E-mail me and I will gladly give you the address & phone# to the vendor I used.
FordMX Dec 20, 2002 10:00 AM
Thanks for the help guys! :thumbsup: Le Pew you have mail! Take care!
Chris
