Air pressure
I have bf goodrich all terrain t/a lt265/60r18 119/116s load range e
Max pressure 80psi on an Ford 150 towing a 26’ trave trailer. What pressure should I run? |
The manual as well as knowledgeable tire shops run the tires at door sticker ratings. It doesn’t matter what the tire pressure says as that’s max for tires. Personally, when I put new E rated Michelin’s on my 2018 I stayed close to the door post ratings. When towing my travel trailer though I usually bump up my rear air pressure to 50/60 psi. Just provides a more stable ride. When not towing I drop the air pressure back down to 38/40 psi.
Perfect. Thank you. |
