have a couple brake controller questions-HELP-
Where do you guys mount them? are they hard to install? what kind is best? anyone got pics of one mounted?
Thanks!!! https://www.f150online.com/f150board/biggrin.gif Do they come with them? ------------------ 1998 150 SC, Lariat, 5.4, Black with a little silver, 4X4, Stock at this time. :( |
Check out https://www.f150online.com/f150board...ML/000130.html - lots of discussion there.
Ian ------------------ 99 Expedition EB 5.4l, 4x4, 4.10 LS WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip |
John,
Locating a brake controller is a real issue. You need to find a mounting location within easy reach, that provides visibility, and won't interfere with the operation of other dashboard components. You also have to be careful you don't hit any wiring when you drill the holes for your mounting screws. I don't have many locations that meet these criteria in my '97 Expedition. Yesterday I mounted a Tekonsha Sentinel controller. I received it in exchange for a Tekonsha Voyager. The Sentinel allows for near-vertical installation, which was necessary to give me the visibility I need. Here is a photo... http://www.voicenet.com/~bluesky/tek...nelmounted.jpg In addition to the problem of selecting the location, I also had a lot of trouble fastening the controller to the mounting bracket. There is minimal clearance between the center console and the right side of the controller bracket. I needed a small adjustable wrench to fit into the space and patiently turn the two attachment screws. ------------------ Dino homepage: <A HREF="http://www.geocities.com/blueskywhiteclouds Low-Tech" TARGET=_blank>http://www.geocities.com/blueskywhiteclouds Low-Tech</A> Ideas, Tips, Hints and Solutions for RV Trailering |
Thanks for the pic, I appreciate the help, Its not like the old trucks where the dash just ends and you can mount stuff on the bottom, I dont have a center console so that makes mine a little easier... I have a controller coming tuesday. So I will hopefully find a suitable place for it, does it need to be in plain sight?
I wouldn't necessary say mine is within plain sight, other people getting into the truck don't tend to notice it. But you do need it to be within easy reach for the driver. And being able to glance at the readings is also a good idea. The location bluesky put his is about where I've got mine too.
------------------ 2k F250 CC SWB 6 speed 4x2 Diesel XLT Super Duty, Woodland Green Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, rear privacy glass TT Pkg, Class IV hitch, sliding rear window, running boards, mud flaps 265/75/16 AS OWL tires, am/fm/cassette/cd, rechargable MagLite Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub SuperChip, Stepshields, Ventshields on windows, rubber bed mat rugged liner bedliner on tailgate, quick disconnect jumper cables unaFORDable (decal on tailgate) Western Diesel Turbo Brake (whoa boy) Finally gauges!!: Pyrometer & Boost on the A-Pillar mount |
Right now i cannot find my brake controller (its somewhere in the garage) because i dont really have a good place to mount it because of my CB so i just put it in when i need it. I dont know what kind you are getting and to be honest, i dont even know what kind i have, i dont tow alot with electric brakes, but the little slot under the ignition, place to put wallets ect...i found out that it fits my controller in there perfectly, it doesent fall out and is really easy to just put in and out, and since it is a plug in under the dash it takes me all of 30 seconds to put it in and take it out.
Brian ------------------ 98 F150 XLT Supercab 4X4 4.6L V8 3.55LS Tonno Cover, Brush Guard, Dukes of Hazzard Dixie Horn, 2 150 watt KC Daylighters, Cobra CB Radio, BF Goodrich All Terrains 265/75/16 http://hometown.aol.com/barto24/brianstruck.html -------------------------- 2000 Excursion Limited 4X4, Black, V-10, 3.73 LS, Tow Mirrors |
I just got a tekonsha, hope to try to wire it up next day or two
What do y'all think about mounting it under the light switch on the left hand side of the dash?
Here's mine. It's visible through the steering wheel.
http://www.zing.com/picture/p378ebc1...2.jpg.orig.jpg |
OK, I got it mounted, I will get a pic up soon, its to the right about even with the panel line in the pic above, I have the wires spliced into the pigtail that came with the truck. Sure do appreciate that one!!!!!
Anyhow, I have one final important question, the instructions for the controller say it must be grounded to the battery, did you all run a wire to the batt for the ground????????????????? I need to know!!!! Thanks!!!! ------------------ 1998 150 SC, Lariat, 5.4, Black with a little silver, 4X4, Stock at this time. :( |
I installed mine with the FORD supplied adapter, ran no extra wires. One of those is the ground. Mounted mine like Bluesky.
In my 98 the trailer dealer installed it, just a little bit over. Turns out it was blocking the computer port. Took it in for tranny problem, dealer test drove and stated nothing wrong. Couldn't run the test because the box was in the way, slug wouldn't drop two screws without charging me (i think it was an excuse because they were busy). I moved it, brought it back, and they tested it. Two days later had a brand new transmission in it! ------------------ 99 F250XLT Supercab LD 5.4L 3.73 LS White/Silver Graphite interior 6 CD changer/Captain's Chairs |
OH, the controller said it needs to go to the battery, you hooked it up to the wire in the connector for the trailer ground?
