brake controller
You can cut and splice wires, or just get your brake controller vendor to sell you an adaptor that will allow direct plug in to an exisiting (factory) under dash socket.
Cost me about $7 extra and saved a ton of time. Did whole job including a neat/careful job on the mounting bracket (for my Prodigy controller, which btw, is MUCH better than my old DrawTite) and it took under 30 minutes, at night,by flashlight. 15 during the day, I'd guess.
x2 on what he said...
wherever you get your controller from (Tekonsha Prodigy recomended), for a few extra bucks, get a wiring harness for it specific to your truck. Makes it completely plug'n'play. Makes wiring the unit up actually easier than mounting it.
Originally Posted by sysman_rick
You SHOULD HAVE received a relay and harness with your truck for the towing package.
So, in my 2007 Screw Lariat with Captain's Chairs, where are you guys mounting your controllers? Any PIctures would be greatly appreciated. Thanks,
Smoke
Smoke
With the Prodigy you can't feel the trailer brakes at all unless you want to. It is a digital proportional advanced accelerometer type of controller. It senses momentum of the vehicle but applies current proportional to the weight,speed, and rate of decent. The Prodigy monitors the connection and the trailer. It will let you know if it's hooked, unhooked or if there is a problem with the wiring. It also has a boost feature that you can set for the wieght of the trailer vs. the weight of the truck. I love mine. Nice smooth stops, no jerking or banging and easy to adjust. Set it once and forget it. It even has proportional braking in reverse.
[/IMG]
