SYNC stopped working
2011 F150
Started the truck yesterday - no icon showing that my phone was connected. Pushed the "Phone" button on the steering wheel and the "Phone" button on the dash unit - nothing. Next step will be to pull the battery cable for 5+ minutes unless someone tells me that's a bad idea. Thoughts? Thanks |
Originally Posted by Cal Stanley
(Post 5152070)
2011 F150
Started the truck yesterday - no icon showing that my phone was connected. Pushed the "Phone" button on the steering wheel and the "Phone" button on the dash unit - nothing. Next step will be to pull the battery cable for 5+ minutes unless someone tells me that's a bad idea. Thoughts? Thanks I'm here to help! Which SYNC system do you have in the vehicle? Let me know; I will work my magic and get you answers. :) Shaay |
I don't know what you mean by "Which SYNC system".
No Nav, if that helps, otherwise, how do I tell? Cal |
(Post 5152114)
No Nav, if that helps, otherwise, how do I tell? Cal That helps a lot! I'd suggest trying a master reset to resolve this issue. The instructions can be found using this link: http://owner.ford.com/sync-technolog...ter-reset-sync I hope this helps. Shaay |
Shaay
Won't work - When I hit the "Aux" button, I see the word "SYNC" for just a second, then it's gone and the radio is playing. Cal |
(Post 5152134)
Shaay
(Post 5152134)
Shaay
Won't work - When I hit the "Aux" button, I see the word "SYNC" for just a second, then it's gone and the radio is playing. Cal Do you get the same result when the PHONE button is pressed? If so, you will need to visit your local dealership to get this issue resolved. Shaay |
Hi Shaay,
Truck runniing in park - radio off - No icon indicating my phone is connected. PHONE button on dash - nothing PHONE button on wheel - nothing AUX button on dash - SYNC shows for an instant, then radio plays MEDIA button on wheel - cycles through radio, sirius, etc, when it cycles to SYNC - SYNC shows for an instant and cycles to radio |
(Post 5152249)
Hi Shaay,
Truck runniing in park - radio off - No icon indicating my phone is connected. PHONE button on dash - nothing PHONE button on wheel - nothing AUX button on dash - SYNC shows for an instant, then radio plays MEDIA button on wheel - cycles through radio, sirius, etc, when it cycles to SYNC - SYNC shows for an instant and cycles to radio Sounds like all of your SYNC functions are inoperable. You will need to connect with your dealership to get this issue resolved. Keep me posted on how it goes! Shaay |
Will do - thanks for the help.
Just got back from lunch - I disconnected the negative battery cable while I was eating - re-connected and everything is up and running again.
