removing my body lift
Ive had a 2" body lift on my 2000 ext. cab F-150 (4x4) for about a year now. Ive decided that i just dont really like it. Anyone know anything about removing these, like cost, hardware, or anything else? Ive heard the stock body mount bolts have to be drilled out so im assuming i would need to get new ones from Ford? Anyone know anything about any of this, info would be greatly appreciated. thanks a lot.
Are you still having problems with it? Hopefully, you kept all the original parts and bolts. I believe, only the front body mounts have to be replaced. You might get lucky if you try a junk yard first. You might want to try looking for a fan shroud as well. And I'm not sure if this is applicable on the 2" lift, but if you cut the fuel hose. Just use the extension and slide the hose back together and use some new clamps. Other than that, I believe everything else is just the reverse going back to stock. Good luck
