Raise 4x2 so it looks like a 4x4
I would like to raise my 2001 F150 Screw 4x2 so that it looks like a 4x4. What is the best way to go about doing this and how much would it cost?
PS: The other day I saw a raised chevy on the side of the fwy with its rear axle almost off the truck. I guess whoever did the job didn't do a quality job. Hope he got some kind of warranty. |
well, you could get some daystar coil spring spacers, that willlift your front endto the same height as the rear end and give the truck a nice stance. just a thought, good luck!
i would go with the 3 inch spindles they should put you around the same as the 4x4.....
I've got the Fabtech 6.5" lift on my black 99 F150 4x2 Screw with BFG 315's. It put me about 11" taller than stock. Just barely fit in the garage now. Had to put 1.5" add-a-leafs to level it out. It rides pretty good, some bounce, speed-o is off 8-10 mph, gas mileage went down (now around 10-12 mpg), have superchip and dual exhaust, adding air intake (on back order, i guess it's being brought in on donkey from mexico), wife's too short complains 'bout climbing up and jumping out. It took some getting used to. for about two weeks I feared I made a big mistake. I love it now. my dealership has done all kinds of freebies cuz they think it's cool too. Plus I own 12 fords for my biz.
If you go this route, keep in mind stock rims have to go. valance has to be trimmed. Have had some difficulty with alignment staying put. seems large bumps add up quickly. something to do with no "possi-lock" or something. but it's all worth it. i'll never go back. |
i went with the 3" spindles and a 2" block in the back.the truck sits the same as a 4X4.
Thank you for your comments! I think I'll go with the Fabtech 3" kit. Does Fabtech provide installation for their products? and for how long?
you should probably order it from a local offroad shop .......and let them install it.......but make sure you shop around almost all of the offroad shops will beat each others prices......check some of their work too......good luck
You can get 3" lift spindles for $249 from here , it says 295 but I bought them for $249
http://www.truckn-store.com/product....lt.asp&ID=6407 https://www.f150online.com/galleries...3770-thumb.jpg |
