BodiLft and Manual Shift Transfer Case
For those of you that have installed a 3 inch bodilift with a manual throw Transfer case...
1. Did you install the Transfer Case Handle extension? 2. Have you had any problems with the Transfer case being knocked out of gear due to bodi flex? Thanks....... |
i did have a competent friend weld an extension in. It works fine and does not ever pop out of gear due to the lift... hope this helps :)
