Steering wheel slightly crooked after alignment..
Replaced a lot of my suspension including tie rods. When I replaced those, I measured and also counted how many turns so I could get them pretty close.
Had to go to Monroe for an alignment. Being that it's a Saturday, the better places weren't open.
Anyway, the steering wheel was slightly to the left, took it back, they rechecked and it's still a little to the left. Barely off, but it bothers me.
I used all Moog problem solver parts. They told me that because I used aftermarket, they probably can't get the steering wheel to line up perfectly. I don't buy that.
Any experts have any insight? Thanks!
They didn't even give a printout of any alignment specs. I did see my truck on the rack for a while, though.
I also just don't even want the same tech driving my truck into their bay. He can't drive a standard transmission and I was cringing listening to him try to get my truck to move.
Either way, I'm not happy. There is no way brand new Moog problem solver outter tie rods are going to make it impossible for my steering wheel to be perfectly centered.
I think they're lazy and/or don't know what they're doing. This is why I never ever going to places like this. Being it was a Saturday, I just didn't have any options.
I'll post the outcome. This will get solved.
Boy on boy this sounds like what I went through. I would wager that very few have ever endured what I did from 2012 to 2013. I had 10 yes 10 alignments done because people could not tighten the Lower control arm bolts on my truck. The truck kept coming out of alignment and I am suspicious that is why my shocks are ruined. They were squeaking at one point because the lca was twisted all the way in opposite directions in the alignment holes. I tried NTB, a well regarded speed shop and finally a local guy got it. Now I just go to Ford. The incompetence is scary and as a result I do every thing I can to avoid having someone work on my stuff. That's just lazy man, good luck
They are supposed to center the steering wheel and then adjust the alignment. The last alignment I had done was on my 05 Dodge Magnum after buying a set of tire. The shop had a laser alignment system that was impressive. They did a 4 wheel alignment since it has independent rear suspension. I got a printout that showed precisely what the alignment was set to. As I remember, it was Merchants Tire close to Richmond, VA.
Yeah, I was working a temporary contract job at the North Anna Nuclear Power Plant at the time, norhtwest of Richmond. It lasted about 6 months and I was off to the Turkey Point Nuclear Power Plant south of Miami, FL for 3 1/2yrs. I've put about 36,000 miles on my car since then with no alignment. I do get my tires balanced occasionally.
I just had my old Toyota done at mechs while I was picking up the 01'& to check it out.
Kid had all the right stuff and it was 15deg off camber,did the whole thing with computer,got a print out....but steering wheel is not perfectly centered anymore.
Means he didn't recheck exact center of steering wheel after getting it into position on the rack to align.
Or that's what I have concluded. It's just a bit off,but I notice it.
Like the new F150 sort of slowly wanders to the right when on flat level ground after a ways,no wind,I noticed and will mention it if and when I get it realigned. The wheel is slightly off center.
