What's the difference?
Mounting, length, and spring rate if it has the coil on it as well. Basically, they aren't interchangeable.
I've looked at both through bilstein and the only difference I can find is on the length.
04-08 collapsed 16.34
Ext. 21.89
09-13 collapsed 16.93
Ext. 21.83
both 46mm monotubes. So since it would never be fully collapsed then I don't see a difference in length being a problem. So is the issue the lower mounting bolt diameter?
I only ask cause I am needing a new set for my truck ASAP. The 04-08 are on backorder as the 09+ are not. Thanks!
Ext. 21.89
Ext. 21.83
