Fox 2.5 bump stops and fabed prerunner guard
OK guys so my custom fabricated prerunner guard has been on for about 2 months and is having some more Fab work done so it should be back from powder coating tomorrow and on the truck again. And here are some pics of my girl. My Fox 2.5 bumps stops just came in along with the bump cans. And Jeff decided to do some Fab work on them to so they will be on tomorrow and I'll get some pics then. I'm also waiting on limiting straps and they should be on in a couple of weeks. I'm Also upgrading my brakes to vented, slotted and drilled rotors and also high friction brake pads to. So stay tuned for more to come.
Also go follow my instagram @OG_PATRICK and on Facebook @Patrick Despain
And my bumpstops are on so I'll upload some pics in just a minute
Just seems like since they're mounted so low you have barely any up travel in the suspension.
Interesting though! You must be using your truck if you've got something like that haha.
And yes about 3" till full bump, but I don't have any exact numbers for ya. And since they're mounted much closer to the rotation point on the control arm I have quite a bit of travel left
I don't wanna be the debbie downer here but have you even cycled this to see where you need your bumps at or if you even need them whatsoever? I'm going to say no because you don't know travel numbers. I see in this pic that you have maybe 2 or 3inches of up travel before that shock rod end smokes your body. if you arent fully bumped before this point then your bump stop is pointless and you are just going to have a ****ty ride. if you have a 3" bump you have essentially 3" of bump you need to use before you overbump. just looking at this I know that the bumpstop is just floating there. you have money in parts, do this right. I forget why you went with such a huge rod end, maybe for some type of clearance but that needs to be addressed. if you shorten that rod end, it will lower your spring, lower the end and give the shaft more travel to move. theres a lot that goes into this, and you really have to think about things unless its more for show which in that case disregard what I say.
bump stops are needed for precautionary reasons. when you have a (expensive) shock that gets beaten on, you like to try and keep yourself from crashing the rod end into the body of the shock, literally. it happens and it can result in a lot of bad things. you use a bump stop to cycle suspension and place in position about a half inch to even a inch away from the shock rod end being completely compressed. you do this because its 1. cheaper to replace or rebuild a bump stop, 2. to save shocks and prevent damage and drivability and 3. because it gives the driver notification when your full bump. trust me you'll know when they hit and they are at full bump ha. anyway basically its just a good idea, some people dont run them some do. some TT dont even have them but thats also because they have suspension cycled in a way where its almost not needed or their shocks are valved as such. limit straps are the exact opposite, you dont want to pull the rod end out so it smashes into the bottom of the body seeing as a huge heavy tire with a bunch of weight pulling it into itself. that and some people like myself have cvs, and they need to be monitored and have precautionary methods to keep them from exploding. hope that helps
But I will keep you guys in the loop of what's going on. Thanks
No, I'm glad you are telling me this because I'm no were near as knowledgeable as you are in this. I just try to gane my knowledge threw Jeff and people like you on the forum, so thank you for your input. I do see what your talking about on the travel. Jeff told me that at full up travel the bump stops will be in full bump. Now if this is correct I don't know but I will ask Jeff to get the truck in sometime and get some exact numbers and make sure everything will work properly... because yes, there is a lot of money in this and I want it to be fully functional. Oh and the huge rod is because it won't clear the axle and boot without it. And this is still in the testing phase so we will have to make some adjustments and fix something's because this is one-off.
