What do i need to clear 33's
I have a 98 f150 with a leveling kit but really want to put some 33's and some different wheels... what size lift if anything do i need
check the search engine out...but most of the f150s come factory with 32 inch tires
so you shouldnt have any problem fitting a 33. just read up on your offsets/backspacing on your wheels to get the look you want. negative offset pushes the wheels out .positive offset stays in closer to the truck. good luck, there are a lot of nice trucks on here to check out and see what exactly you were looking for |
are you 2wd or 4wd?
stock wheels or aftermarket wheels? if aftermarket wheels what are the specs on them? (width and backspacing specifically) once you answer those you will get a correct answer. |
I'm assuming 2wd since he said leveling kit, unless he has those god awful aftermarket keys.
I have 35's with a 3" body lift and no rub at all.
Originally Posted by dropzone265
(Post 4780779)
Originally Posted by pizzaman711
(Post 4780782)
You must be 4x4 then, there's no way you could do it on a 2wd.
And that's with trimming. If the op is going with aftermarket wheels, it's a safe bet he'll need a minimum of 3" to clear 33's with possible minor trimming. See my sig for more info.
'collins, I am selling my fabtech 7.5in lift if your interested, just send me a PM
Just need to have 4wd. My truck has 33x12.5 and is 100% stock suspension.
https://www.f150online.com/forums/me...f150onlin8.jpg |
Your truck is also a complete different bodystyle and suspension style....
and 4wd....
mine is 4wd.... just want to get some 33's to look a little tougher look and want to still tow my drag car.... also was wondering if a edge or gryphon would help out on towing my car...
Wait your 4x4 and can't clear 33's?? You definitely should be able too. And by leveling kit did you just crank the torsion bars or did you get aftermarket?
You should be able to clear 33's stock. With the front leveled there should be zero issues, even with aftermarket wheels.
| All times are GMT -4. The time now is 05:59 AM. |
