bags
If by plug n play u mean a rear air bag kit I have one. I went with the air lift brand ride rite kit. No drilling required and installation should take a couple hours. I ran my air lines into the cab. Here's a pic with about 800 pounds in the bed and my tt hooked up. They work great.80 psi in them for this load. Got mine for under 200. If I'm off, please explain plug n play.
[IMG]
[/IMG]
[IMG]
[/IMG]
you don't need to cut the frame if you don't want to lay out. But you will bottom out on your frame. I'm assuming your talking about lowriders. To sit your truck on it's NUTS you will have to put a step notch in.
look up anahiemdrew he is as low as you can get without cutting, but remember he also has a body kit too, so it seems lower
edit* for some reason i thought you had an 04-08
Checked your profile and truck looks sweet. I just got out of the 2 wd scene in December. Wasn't sure if u were asking for lowering or hauling purposes, appears for lowering. Heres my 04 Sierra that I traded in. 2 inch shackle level and 22s.
O[IMG]
[/IMG]
O[IMG]
[/IMG]
Well looking for lowering and hauling lol. That truck looks nice
. What made you want to go 4wd? Thanks for the comment I've had this truck for 2 yrs now. Trying to make her 1 bad a$$ truck sine all there is fixed up chevy's around here.
I live in Idaho and it snows a fair amount. Also the 40 series tires weren't great for camping. Also had blacked out head and tails just not in that pic.
thats a good reason why haha. is it pretty sick going camping in? been wanting to take the ford to the lake here but scared gonna get stuck haha. i bet that looks sick whith the blacked out heads and tails..
I tried e-mailing RideTech and the only thing I got was (not exact wording) "You have to notch the crossmember." I've had a load in my truck that sat the truck on the axel and I like that height so I'm pretty sure I don't have to notch my truck for it to fit but not definate, I did notice however in the instillation instructions that it mentions that the exhaust has to be directed out before the tire (or if I can help it just around the bags, I like the rear exit exhaust).
