F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Suspension (https://www.f150online.com/forums/suspension-28/)
-   -   Belltech's Lifting and Lowering Struts (https://www.f150online.com/forums/suspension/444926-belltechs-lifting-lowering-struts.html)
T_S_S Mar 24, 2011 12:18 PM
http://thesuspensionsource.mybigcomm...68611_zoom.jpg
Belltech engineers focused their attention on tuning the low speed compression characteristics of this shock absorber, which is responsible for controlling your Sport Truck or SUV’s pitch and roll, dive and squat to help keep you confident and in control. The “Progressive” rebound tuning will complement large aftermarket wheels, keeping the ride smooth but firm and in control. The ultimate in Premium Street Performance solution
  • Vehicle specific applications
  • Oversized Construction provides additional damping control
  • 15mm piston rod, 35 mm piston and a 55 mm shock body
  • Internal Teflon coated bushings and piston seals avoid metal to metal contact, provides lowest possible friction resulting in long lasting performance
  • Increase in handling and performance at maximum comfort
When used on the 2004-2010 Ford F150 it will lift or lower your truck up to 2 inches. Can be adjusted in 1/2" increments.
$214.99 for set of 2
http://thesuspensionsource.mybigcomm...0-%282%29.html
