Is This A Complete Kit?
I found a guy selling his Pro Comp Stage II kit that he switched out for a Rize 12"
This is the parts list he has for the Pro Comp. Can you guys tell me what may be missing from the list. Here is a list of everything I am selling: Part # 90-1964 - Brackets (2) 90-1908 - Differential Drop Bracket (2) 90-1907 - Differential Drop Brace (1) 90-1104 - Compression Strut Mount (2) 90-1912 - Sway Bar Drop (2) 13-90390 - Leaf spring U-Bolts (2) 90-1917 - Rear Cross member (1) 90-1083 - Brake Line extension Bracket (2) 90-1897 - Front Cross Member Bracket (1) 90-1977 - Pro Comp Coil Over Front Shocks (2) 90-2415 - 1 inch Spacers (2) 90-2403 - Compression Struts (2) MX6009- Pro Comp Shock Absorbers Rear (2) 92-254F - 6 inch Leaf Spring Block spacer (2) Factory Ford Leaf Spring Spacers (2) 6 inch Knuckles (2) Brake Line Extension Cables (3) Factory Leaf Spring Mounts (2) Factory Skid Plate (1) Skyjacker 6 inch leaf springs (2) Factory Leaf Springs (2) Multiple Bolts, Washers, and Nuts. http://i886.photobucket.com/albums/a...m/DSC02174.jpg http://i886.photobucket.com/albums/a...m/DSC02165.jpg http://i886.photobucket.com/albums/a...m/DSC02166.jpg http://i886.photobucket.com/albums/a...m/DSC02167.jpg http://i886.photobucket.com/albums/a...m/DSC02168.jpg http://i886.photobucket.com/albums/a...m/DSC02169.jpg I assume these are the factory and SkyJacker 6" leaf springs http://i886.photobucket.com/albums/a...m/DSC02171.jpg http://i886.photobucket.com/albums/a...m/DSC02172.jpg http://i886.photobucket.com/albums/a...m/DSC02173.jpg Also, how much stiffer does the 6" Skyjacker Leaf springs make the truck or a similar set.. ? Any Help would be greatly appreciated! :thumbsup: :beers: |
There may be more missing, but seems at first glance that 2 U bolts are missing. Maybe some mounting hardware (nuts/bolts), but I would look into just buying some of that new.
Originally Posted by mdhawkin
(Post 4427428)
Its a good price... Just want to make sure I'm not buying this then spending a couple hundred on other parts.. |
