F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Suspension (https://www.f150online.com/forums/suspension-28/)
-   -   345/75-16's (https://www.f150online.com/forums/suspension/433859-345-75-16s.html)
gearhead5225 Nov 25, 2010 12:37 PM
345/75-16's
I have a 2002 2wd with an 6" RCD lift and soon to have a PA 3" BL and was wondering if you guys think a set of 345/75-16's would fit? I test fitted a buddies 38.5-10.5-16 bogger on it and it cleared but the thing is it was bald as hell...also if i can get a tire like that to fit what gears you think i should run? 4.88 or 5.11?
wandell Nov 25, 2010 10:21 PM
I think a 37x12.50 would be a much better fit.
gearhead5225 Nov 26, 2010 07:16 PM
only reason i was thinkin the 345's over the 12.5's was cause i get a major discount off the new BFG KM2's through work to where there practically a steal as compare to paying full price for a set of nittos or somethin else, you think the one inch width will make to much of a difference?
wandell Nov 26, 2010 10:13 PM
Depends on the width and backspacing of the wheels you are using. If you have a 10 inch wide wheel with 4.5 inches of bs, you may have serious rubbing.
gearhead5225 Nov 27, 2010 09:55 PM
i have 16x8 mickey thompsons with 4-7/16's backspacing
wandell Nov 27, 2010 10:27 PM
It will be really tight. Sorry I can't give you a definate answer but you are dealing with an odd tire size. I'd suggest test fitting one.
gearhead5225 Nov 28, 2010 07:40 PM
cant exactly test fit one either...which prooves to be a problem since any tire i order has to have a down payment on em.
wandell Nov 28, 2010 09:59 PM
You should be able to find someone locally that will be willing to mount and test fit one. Just make sure it is understood that you are purchasing a set of tires from them.
madmaxwell87 Dec 16, 2010 02:46 PM
Thats a 37x13.5" tire. His boggers fit cause they were narrow. Those are too wide for a 8" wide wheel. Your only supposed to go 4"s wider than the wheel or in this case 12"s. If you do get them and get them to fit gearing depends on whether you do more city or highway driving. Id say 4.88
gearhead5225 Dec 17, 2010 12:11 PM
ive pretty much decided on gettin a set of 17x9 wheels and a set of 37x12.50's, i do alot of intown driving and not so much highway
