f-150 with low front corner
Just bought a used f-150 and can't believe I did not see this 5 days ago.
I also apologize as I am sure that there is info all over the boards but to be honest, it seems the forums search just does not work right now.
The left side of my truck is a solid inch and quarter lower on the left front. I am measuring from center of hub to fender to rule out any tire differences. The left rear is also a bit lower but not as much and to be honest I think that the lower front corner is acutally jacking up the right rear.
A careful look underneath does not reveal to me any major frame bending and the leafs in the rear 'look' ok.
Ok, sounds like I might just need to adjust the torsion bars. Does this sound reasonable to all you ford truck experts?
Sounds like it is a pretty easy procedure but just throwing this out for comments.
I had the EXACT same issue, but, it was after I went through an issue with a theft/recovery, etc.
Long story short, they replaced my front left strut/spring with one from a salvage yard, and it had already been over-compressed and was shot.
I had them replace it with another one, and it sat it up like it should be.
Now, other options may be to get some Bilstein leveling shocks, level kit on the one side, etc if you are looking for a temp workaround, but replacing that corner's shock/strut would be the best bet to get it back to level all the way around.
