Lift shackles - shims needed?
Was looking at installing 2" lift shackles on my truck and was wondering if I needed to install shims as well. I know those who are installing drop shackles should.
I have a 2.5" leveling kit on the front and even though I proved to myself that it was perfectly level, it looks a little off to me so I want to add about an inch or so of lift to the back. I just dont want to f anything up by doing so.
Lift the rear then support with jackstands...the axle will then droop. Reposition the jack under the axle on the side you're working on and jack it up until you can relieve the tension on the spring and shackle. It'll make sense when you start doing it.
Final notes: The bottom bolt should be easily removed, but you must jack up the axle until the top bolt clears the top of the frame support. It may be easier if you dropped down the spare tire, but I was able to finagle the bolts enough to remove/install them without moving the spare at all. All in all, it should take about 1 to 1.5 hours tops...pretty easy mod.
With the help of a 2x4, I jack at the diff when I need to lift the entire rear end at the same time (which is what I did here). My jack stands were on either side of the truck, supporting at the frame. This allows me to re-position the jack under each side of the axle to relieve the stress on the springs and free/install the shackle. Also this does not require air tools at all...simple hand tools (1/2" ratchet/socket and wrench to hold the nut - don't remember what size though).
Forgot to mention to lube the urethane bushings and metal sleeve like crazy or they might squeak over time. I couldn't find my tube of lithium goo so I just used a bunch of red bearing grease I had lying around. If I had thought about this sooner, I would've drilled and tapped a zerk fitting...now that I remembered that, I feel like drilling/tapping the fitting this weekend.
Who sells those lift shackles? My 2.5 leveling kit is also driving me nuts. I swear it looks like the front is higher now. My running boards look like there is a slight rise to the rear, but the space between the tire and wheel well looks a little larger on the front than the rear. A tape measure has them at the same distance.
Did you need any type of shock extension?
Not sure if you already ordered, but I got the same thing on an Ebay auction last year, havent had any issues with them.
http://cgi.ebay.com/ebaymotors/2-Lif...Q5fAccessories
Gave me a little over an inch of lift. I actually ended up putting another 1/2 block in there (courtesy of Kevin at AS) to get the ride height I wanted.
Good luck!
Good luck!
