Sponsored by: CARiD
Leveling Kit
Old Feb 4, 2010 | 09:55 PM
kyleboyf150's Avatar
Post Leveling Kit
Hows it goin everybody
I am about to install a 3" leveling kit on my 2004 F150 this weekend, and although i have instructions with the kit i would really like something to look at thats labeled to get an idea of what i'll be doing before i actually do it. i've never done any extensive work past the tires and was wondering if anyone knew where i could look at a diagram of the sway bar, control arms, cotter key, arm ball joint, etc...
Old Feb 5, 2010 | 12:06 AM
05crewzer's Avatar
first off, welcome to the site.
second, 3" is THE max and the angles arent good for daily driving. 2.5 should be your max.
check out the technical articles. i havent looked yet but if there isnt one i will post one myself. its pretty easy to install. you really dont need a diagram of anything, just one step at a time. i think one member has posted a how to on the AS kit. tomorrow i will post a how to on the kit i have. should help.
there are a few pieces of advice like :use a limiting strap to hold the upper control arm to the spindle to not extend the cv axle or bind lower ball joints. be careful of the upper ball joint to not strip the threads. its a pita to fix. the upper control arm will be very low hitting the coil be will be fine when the truck has its own weight down.
Old Feb 5, 2010 | 12:20 AM
islandfordguy's Avatar
give these a try. the first one is pretty thorough, the second mostly shows some photos of the relevant anatomy. i planned to use them myself, but ran out of time and had the front done at a shop. still did the rear on my own. hope this helps.
https://www.f150online.com/forums/su...t-install.html
https://www.f150online.com/forums/su...cs-inside.html
Old Feb 5, 2010 | 12:31 AM
05crewzer's Avatar
that was the one i was referring to but couldnt figure out how to post it. well thanks.
the last i havent seen yet. good looking out.
Old Feb 5, 2010 | 07:14 PM
hllon4whls's Avatar
Also look on youtube. There are 2 videos. They may or may not be the kits that you have, but procedure is basically the same.
Old Feb 5, 2010 | 07:33 PM
mhockey9090's Avatar
Take a picture of your angles after you install it
Old Feb 5, 2010 | 09:37 PM
Thanks guys i really appreciate all the help and info. i just hope i don't get rained out of installing it tomorrow. I'll be sure to get some pics when i do though.
Thanks Again!
Old Feb 8, 2010 | 05:19 AM
idegarandnanis
Guest
Posts: n/a
I INSTALLED A 2" LEVELING KIT AND ROSE UP GOOD.. HELPS YOU OUT VERY GOOD.. BUT BEFORE I USED TO GET 14 IN THE CITY, NOW I GET 11 .. THINK IT OVER..
Old Feb 8, 2010 | 07:00 PM
alex7191's Avatar
i don't understand. did you put bigger tires on that are throwing off your calculations?
