F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Suspension (https://www.f150online.com/forums/suspension-28/)
-   -   Replace the Rancho's (https://www.f150online.com/forums/suspension/404644-replace-ranchos.html)
bdenglund Jan 27, 2010 05:18 PM
Hey guys
Its time to replace the rancho 5000's. Ive had them on for about 4 years and 100,000 miles. When i got them i think they had a life time warranty. Does anyone one else remember that and how do I go about having that warranty own up.
Galaxy Jan 27, 2010 06:52 PM
Ummmm, I'm gonna go out on a limb here and say that warranty is against manufacturing defects and not normal wear and tear from a life well served...i.e. 100,000 miles.
Good luck though and please let us know the results of that phone call.
ShockGuys Jan 28, 2010 10:04 AM
This is true, they're warrantied against defects, not normal wear and tear. 100,000 miles is an long life for shocks, you got your money's worth.
dflw_99 Jan 28, 2010 12:42 PM
agreed same way on brake pads and any other wear item like that
oscar_a_wiggy Jan 28, 2010 01:27 PM
click on "warranty" at the top of this page..........
http://www.gorancho.com/assets/support.swf
oaw
oscar_a_wiggy Jan 28, 2010 02:05 PM
compare to bilstein warranty...............
Bilstein is world famous for manufacturing some of the most durable, longest lasting shocks available.
In fact, the 5100 Series shocks are comprised of components originally designed for off-road
motorsports. Bilstein is so confident that these shocks will out last your vehicle that we back the
product with a Limited Lifetime Aftermarket Warranty. If a Bilstein shock fails during normal wear and
tear, you’ll get a new shock absolutely free.
oaw
Galaxy Jan 28, 2010 05:33 PM
Yes, read your warranty link...it says what we're saying it says. "Warranted against defects in materials or workmanship". Your normally worn out shocks at 100,000 miles do not fall into this category...quite the contrary, if these shocks performed well for 100,000 miles you have just proven that there was obviously no defects in these parts.
I think you are having trouble grasping the difference between "failed" and "worn out".
For comparison sake, think of it this way (because this is you)...A set of tires with 50,000 miles on them worn clean down to the wear bars. Try rolling into Americas Tire or calling GoodYear and tell them you want your tires replaced under warranty and see what that gets ya!
You get an A for effort, but this isn't going to net you a new set of shocks.
Windsor Jan 28, 2010 06:27 PM
My understanding is that if you're the original purchaser, and you'd need your receipt to prove that, then if you wear them out, they will replace them under warranty. The finish is not covered, however.
bdenglund Jan 29, 2010 02:33 PM
Ok, I get it, I get it. They're not going to be under warranty Thank you.
Brett
jdruzik Jan 29, 2010 03:38 PM
The Rancho r5000 shocks are warranted for life under normal conditions and are on the same vehicle they were purchased for... This info is taken directly from their warranty page... www.gorancho.com/assets/support.swf
