Want to run 33's on 2wd.
Hey, I have a 97 f-150 ext. cab 2wd and i would love to fit some 33's under it. Right now its all stock suspension wise so if anyone could tell me how much lift i will need would be awesome. Thanks
you can fit them with a 1.5 inch front spacer
Wow, i never would have thought that. Does anyone have recomendations for leveling kits for a 97 2wd?
I measured my tires (255/65/16) from the center of the rim to the ground and got 14" x 2 would be 28". Is that right, it seems kinda small to me. Are 33's (305/65/16) ? |
should be 29"
Oh yeah......maybe daystar kit.... |
Originally Posted by badd97f150
(Post 3963695)
I measured my tires (255/65/16) from the center of the rim to the ground and got 14" x 2 would be 28". Is that right, it seems kinda small to me. Are 33's (305/65/16) ? The tires you will need to be looking for is 285/75/16s which are 33" tires. You would be suprised, because I ran 285/75s on stock suspension but they do rub the sway bar. The leveling kit will keep them from rubbing at all though. |
Is the daystar kit the same for the 2x4 and 4x4 just so i know? What do you guys think of a 2.5" in the front (does daystar make one?) and 1" or 1.5" blocks in the back on 33"s? That should bring me up to a stock 4x4 height right?
(Post 3963718)
You would be pretty close to 4wd height in the front, but you might be a hair shorter in the back. A 3" body lift will have you a hair higher than a 4wd just about all the way around, and looks really good with 33s. |
with the 1.5 daystar he can fit 305/70's/stock rims with minor rubbing cant he?
Originally Posted by offroadn'98
(Post 3963818)
I have 33in nittos on mine and i used the hell bent steel leveling kit, and my 33's fit fine with out any rubbing. The hbs kit was super cheap too.
militia you have a new body style,totally different than the obs
OP-to fit 33's youll need the daystar 1.5" coil spacer and stock rims, if your going to use aftermarket wheels youll need more lift because they have less offset pushing them farther out. A 285/75/16 is a 33x11.5 and will fit on a stock wheel and with just a coil spacer. The stock wheels are 7.5"s wide so you cant go any wider than a 11.5" tire so a 305/70/16(33x12.5) like i run requires more lift and a wider wheel. There is a vast difference between a 2x4 and a 4x4 leveling kit. A 4x4 uses torsion bars so a leveling kit are torsion keys. A 2wd uses coils so you need coil spacers. And lastly search, theres a ton of threads about this exact topic recently. |
if you check out my gallery you can see a 98 2wd with just a 1.5" daystar and 285/75/16 bfg all terrains. its very simple and well worth it.
Originally Posted by madmaxwell87
(Post 3964011)
The 4.5"s I mentioned is just a general rule for good tire wear. You can of course go wider but as you mentioned the tires will wear funny cause the skinny rim will pull the edges in. I have 5.5"s of lift in the front and had to trim the valance and get slight rubbing on the rear fenderwell with my 305/70s so Id be hard pressed to think you could get away with just slight rubbing on a truck with just a coil spacer.
http://i245.photobucket.com/albums/g...mas08052-1.jpg |
I used a daystar 1.5" kit, easy to install and cheap. I also put on 295/75/r16 bfg a/t ko's on it, which did rub on the rear fender well. Trimmed that, still rubs very slightly at full lock, otherwise unnoticeable.
http://img.photobucket.com/albums/v3...7/DSCN2506.jpg |
| All times are GMT -4. The time now is 02:40 AM. |
