Sponsored by: CARiD
A shock question?
Old Nov 5, 2009 | 10:50 AM
SilverScrew01's Avatar
A shock question?
Can someone explain cranking shocks to me?
And which shocks you can crank?
Old Nov 5, 2009 | 11:00 AM
mdhawkin's Avatar
It refers to adjusting preload, which can change your ride height. This is not something you can do with OEM coilovers. Many aftermarket coilovers provide this capability. Here is a link to a pic of adjustable coilvers. You can see where you can adjust your preload. http://image.sporttruck.com/f/104051...ver_shocks.jpg
However, I see that you have a 2001, if its 4x4 then you do not have coil overs but torsion bars instead. You can "crank" those, to do so there is a cross memeber under the truck where one end of each bar connects. There are key ways in there that has a bold that can be tightend to raise your ride height. If you do this you need an alignment afterward.
Old Nov 5, 2009 | 11:54 AM
wandell's Avatar
RIght.
