Sponsored by: CARiD
new shocks..
Old Jul 31, 2009 | 04:15 PM
01f1502wd's Avatar
new shocks..
my stockers have 98k mi on them, and from watching my truck bed many people say I need new shocks. I got recomended Bilestins.
Is there any way how I could get maybe slightly taller shocks and get any lift out of it? of should I just buy the same size/length? and i guess "shot" shocks sag? so w/ new ones it would bring it up a touch?
Old Jul 31, 2009 | 08:51 PM
Galaxy's Avatar
Nope, your logic is completely incorrect. Shocks support zero weight and therefore, for that purpose alone, can not and do not lift your truck or any other vehicle. If you think your truck is sagging, it's either your imagination because you think think the shocks support weight, or your springs are breaking in and therefore settled slightly. But the shocks are not a contributor to this.
You always want the stock length shock if you don't have a lift. 98k, yea you could use new shocks!
Old Jul 31, 2009 | 09:08 PM
01f1502wd's Avatar
so what exactly do shocks do? just help rebounding over bumps?
Old Jul 31, 2009 | 09:47 PM
FX41's Avatar
They are shock absorbers, they absorb the shocks to the suspension so that the ride is nice and smooth.
Old Jul 31, 2009 | 10:01 PM
01f1502wd's Avatar
thats what I thought. some people "thought" will like taller shocks you can get an in. or 2. but i didnt think so/ curious. time to find some bileistins.
Old Aug 1, 2009 | 12:12 AM
Galaxy's Avatar
Shocks control the spring (be it a coil, leaf, torsion bar, coil-over, etc) movement in two forms... Rebound and compression. When the spring is forced to move by some outside force, i.e. A bump in the road, the shock controls how fast or slow it moves in its initial direction and also controls how fast or slow it returns to its original undisturbed position.
If you ever need proof that a shock doesn't support anything, take the shocks off with the vehicle sitting on the ground on all four. It'll sit there just fine!!
Old Aug 1, 2009 | 12:17 AM
LOHfootball53's Avatar
My shocks support weight.....
Old Aug 1, 2009 | 12:28 AM
01f1502wd's Avatar
ok so when a car is moving w/o shocks and it hits a bump....what then?
(this seems like something from kindergarden....but anyways go on)
Old Aug 1, 2009 | 12:45 AM
BAD DRVR's Avatar
Your truck would bounce all around like a spring. Shocks dampen the bounce. Move a shock with your hands. They move, just very slowly. This allows the spring to move up or down quickly at first but then move in the opposite direction with a lot of resistance.
Old Aug 1, 2009 | 12:50 AM
01f1502wd's Avatar
thats what I thought...so what would be a good bilestin? or monore?
Old Aug 1, 2009 | 12:58 AM
BAD DRVR's Avatar
alot of folks swear by the bilsteins but do a little research to find out the differences in characteristics
Old Aug 1, 2009 | 01:18 AM
01f1502wd's Avatar
what kind you got?
Old Aug 1, 2009 | 01:44 AM
BAD DRVR's Avatar
Well, I'm a little different. I have an 8" lift so I have to use longer shocks. I'm using CST which were part of the lift package. They seem to be working fine for me.
Old Aug 1, 2009 | 10:27 AM
Phoenix13's Avatar
Call up Camburg and order a set of their coilovers, which are made by Sway-A-Way but specially valved for the F150s and will level your truck out. While you are at it order some of their S-A-W 2.5" reservoir shocks for the rear.
You will love the ride...
Old Aug 1, 2009 | 10:29 AM
Phoenix13's Avatar
i just realized you drive an 01.
My bad! That info is good for 2004+ though...
