2002 F150 crewcab 4x4 Shocks????
I am thinking of changing my shocks soon? So I was looking for some input on which ones you guys go with? I dont want to spend an arm and a leg but I want something that will give me a great highway ride since I am on there most of the time, but something decent if I go off road. I have a 3 inch body lift and the torsion bar lift running 35's. I would appreciate yall's input.
One more question. Should I buy a longer shock since I have a 3" body lift and the torsion bar lift? I have the 3" in blocks on the rear end so should I go longer in the rear also? I am thinking that since it is only a body lift and torsion bar lift I should just run stock height shocks. I hope somebody knows the answer to this.
Yes, you require a stock length shock. The fact that you have a body lift and/or your torsion bars jacked up amount to absolutely zero as far as the suspension is concerned. As for your blocks in the rear, that's a different story. Are your blocks in addition to the stocks ones or a replacement for them?
Well when I purchased this truck it already had the body lift and I was guessing a torsion bar lift since it sits alittle higher in the front than my buddies with only the body lift. It does have I believe 2.5" to 3" blocks on the back, I dont know if that is stock or what. Mine and my friends sit dead level in the back though, my front end is alittle higher. I really do appreciate your reply on this matter.
You can read more about it here - http://www.shockwarehouse.com/news/m...ecial_2009.cfm.
