lift in - wheels on!!
spent all day sunday installing pro comp stage one 6 inch lift. had to tap some of the holes that pro comp.....MISSED!! aal and 2.5 block in the rear....level but will nose up under load, might go with 4.0 block. wheels are DC-1's 18/9 , tires **** cepek fun country radials 305/70/18. pics in album have to take time to upload all of them
Looks pretty stellar! So the aal alone didn't level the truck out? I got the same lift and the front sits a little higher than the rear. I'm gonna throw the aal in next week. I havent had it loaded yet but i would imagine that it would look like a dog scratchin its *** under load.
Even Better for $109.95
Eagle Alloys 1352-8994
$109.95
Brand: Eagle Alloys
Product Line: Eagle Alloys 135 Series Wheels
Part Type: Wheels
Part Number: AEW-1352-8994
Rim Diameter (in): 17 in.
Rim Width (in): 9.00 in.
Backspacing (in): 4.625 in.
Offset (mm): -8.00mm
Wheel Material: Aluminum
Wheel Finish: Polished/Black
Wheel Construction: 1-piece
Beadlock Included: No
Beadlock Functional: No
Lug Nut Seat Style: Conical seat - 60 degree
Lug Nut Shank Diameter (in): in.
Washer Outside Diameter (in): in.
Hub Centric: No
Center Cap Included: Yes
Load Rating (lbs): 2,100 lbs.
Valve Stems Included: No
Quantity: Sold individually.
Wheel, Series 135, Aluminum, Polished/Black, 17 in. x 9 in., 6 x 135mm Bolt Circle, 4.625 in. Backspace, Each
Eagle Alloys 135 Series wheels--looking for something different?
Designed specifically for rear-wheel drive vehicles, these Eagle Alloys 135 Series wheels feature one-piece construction and tough, edgy styling to add that custom touch to your ride. Eagle Alloys 135 Series wheels also feature light weight for less rotating mass, and high strength for use on trucks and SUVs. These cool Eagle Alloys 135 Series wheels are available in your choice of a black or polished finish.
The Real Deal
**** Cepek®
DC-1® Wheel
Black
New to the **** Cepek Line-up is the DC-1 Black Wheel Featuring a Gloss Black and Machined Finish with A Tough Layer of UV Clear Coat Protection for Superior Durability and Ease of Care, Even in Harshest of Climates.
The DC-1 is a Super Strong, Aluminum Wheel Built Especially for Today's Trucks, SUV's and 4X4's.
* Built With Maximum Caliper Clearance for Today’s Modern Trucks
* Clear Coated for Added Protection in Harsh Climates
* Polished Stainless Steel Center Cap That Won't Rust or Peel (Included)
* Air Sensor Friendly
* Lifetime Limited Guarantee Against Structural Defects
Part # - 979462
Size - 17X9
Weight - 27 lbs
Bolt Pattern - 6-135
Backspace - 4.53”
Offset - -12mm
Max Load - 2,500
Mickey Thompson 979462
$185.95
Brand: Mickey Thompson
Product Line: **** Cepek DC-1 Aluminum Wheels
Part Type: Wheels
Part Number: MTT-979462
Backspacing (in): 4.530 in.
Offset (mm): -12.00mm
Wheel Finish: Natural/Black
Hub Centric: No
Load Rating (lbs): 2,500 lbs.
Wheel, **** Cepek DC-1, Aluminum, Natural/Black, 17 in. x 9 in., 6 x 135mm Bolt Circle, 4.530 in. Backspace
Tough, high-quality, good-looking wheels from an off-road legend!
These **** Cepek DC-1 aluminum wheels are designed especially for today's trucks, SUVs, and 4x4s. DC-1 wheels are built with maximum caliper clearance for late model applications. These wheels are available with polished, chrome, or black finishes and include stainless steel bolts, center caps, and are air-sensor friendly.
