F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Suspension (https://www.f150online.com/forums/suspension-28/)
-   -   Leveling kit, 35's and 2wd? (https://www.f150online.com/forums/suspension/355863-leveling-kit-35s-2wd.html)
cortinas Dec 11, 2008 10:47 PM
i know you cant run 35's with just a leveling kit on a 2wd because of the rubbing. but all of the rubbing is done on the lower valance right? so if i took off the lower valance would i be able to run 35's? thanks
jmt0645 Dec 12, 2008 11:15 AM
its not just the lower valance, also the rear of the fender liner. if you have an '04 or newer, give autospring a call and tell them what your wanting, they'll custom make a leveling kit for what you want to do.
wandell Dec 12, 2008 12:13 PM
You can fit just about any size tire if you use a sawsall. However, that doesn't mean it will work well or look good.
skeeter_usaf Dec 12, 2008 01:37 PM
ha ha thats funny wandell, sawzall. Yeah best way is to save up some more money and do it right becaus eI am assuming thats what the hold up is.
Fifty150 Dec 15, 2008 11:45 PM
35" tires will work much better on a suspension lift.
